11-29-2017, 01:19 PM
Originally Posted by blykins
Can you email or text me a pic? 502.759.1431
It's a mystery as to whether or not that head actually exists. Most believe that the molds were worn out and it's actually a C5 cast number, which would make it a factory 427 MR head.
If it is, then the chamber sizes on those were in the upper 80's, which would mean that you would need to find a replacement head similar to that size. The Pond heads would be the only ones that I could think of, otherwise your compression ratio would go sky high with an Edelbrock, BBM, Survival, etc.
Ok, I will send you some photos this evening. Thanks
