Old 11-30-2017, 03:18 PM
krausewich krausewich is offline
Cobra Make, Engine: MidStates, 351C, 4spd, 9"
Send a message via AIM to krausewich
CR drawings provide a block reference angle of 2.5 deg. Trans mount angle at 1.5. Not sure what actual driveshaft angle is... I believe that the driveshaft will be out of alignment in sideview and plan view (overhead), so you should not be in alignment either way, which is a good thing. Moch it up with 3 and see how things lay out. Hope it helps.
Mike.
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
