Old 12-08-2017, 10:09 AM
RockBit's Avatar
RockBit RockBit is offline
Cobra Make, Engine: ERA #812 427/482 FE
Originally Posted by cycleguy55 View Post
The low point on my car is the bellhousing which I suspect is very common if not nearly universal. I've had it make light contact with parking lot speed bumps a couple of times and that's enough so that I now avoid them whenever possible. If I can't do that I take them VERY slowly and/or on an angle.
Mine is the lowest point also. It is a QuickTime, so it has a very narrow flange. I worry about hitting it on speed bumps and am extremely careful.
Tortuga- Are you confident the there are no cracks in the back of your block where the bell housing bolts on?
Chris
