Old 12-10-2017, 12:43 AM
hinoonaz hinoonaz is offline
Cobra Make, Engine: FF5 347 stroker
I replaced the radiator with a fluidyne until it failed at the corners. A weeping look on the fins when I pulled it out. Replaced with identical aluminum from on line for a third of the cost. I mean identical as from an 89 mustang. The repair shop said they were not designed to be repaired. I'll just spend another 125 at some point for another radiator (two years ago). Shroud makes a big difference in cooling by not using the plastic mustang setup.
