Thread: pinging
  #22 (permalink)
Old 12-10-2017, 02:58 PM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Default comp cam
hi,
Comp grinds their cams 4 to 5 degrees advanced so it is too far advanced when installed straight up. Get a bushing kit and retard the cam 4 degrees.Also check the total advance of timing at 3500 rpm, it should be 32 degrees. You can put a advance limiter in the distributor if needed.
Perry.
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
