Thread: pinging
  #23 (permalink)
Old 12-10-2017, 04:02 PM
blykins blykins is offline
Originally Posted by HighPlainsDrifter View Post
hi,
Comp grinds their cams 4 to 5 degrees advanced so it is too far advanced when installed straight up. Get a bushing kit and retard the cam 4 degrees.Also check the total advance of timing at 3500 rpm, it should be 32 degrees. You can put a advance limiter in the distributor if needed.
Perry.
Hold on a second now....
A camshaft installed straight up means that it doesn't have any retard or advance in it at all. Comp Cams does grind most of their stuff 4 degrees advanced. You can adjust it with the timing set from there. Installing it straight up wouldn't be too far advanced....
Also, a "bushing kit" is a Chevy thing.....not a Ford thing.
Different engines need different amounts of timing. A 3500 rpm total ignition timing rpm is a band-aid for what's wrong, and in reality will make the car extremely lazy. Cobras need a 2500-2700 rpm total ignition timing rpm.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
