Old 05-27-2002, 05:27 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Street motor, not race motor. When assembling my 351, engine, the machinist posed the same question. The rocker arms should last the life of the engine, and not be considered a replacement item after a season or two. The Comp steel Pro-Magnums are forged steel.
When you pull the heads for a valve grind, and spring replacement, send the rockers back to Comp for a rebuild, and roll 'em for another 50 - 100k miles.
Cost wise, the Gold race are about $299/set. The Pro-magnums, about $259/set. (Summit/Jegs)
