Old 12-13-2017, 06:17 AM
john chesnut john chesnut is offline
It's the car with the flag paint job. You can just see part of it on the front of the hood. I'll try to find a picture that shows it.
There are a lot of differences between the Shell Valley Cheetah and mine.
- I'm using an MGB windshield. I think its the perfect look and size. The glass is readily available for under $100.
- The body is low on the Cheetah. All of the original had the air cleaner/carb sticking through the hood. I didn't want that. I sculpted a hood bulge that was as low as possible.
- I molded in reverse air vents in the hood to allow engine heat to escape.
- I molded in the dash, cockpit sides, and rear bulkhead so that the body positively locks into place on the frame.
- The seating position is as far rearward as possible. This allows for greater leg room which allows a lower seating position. And, more room between the rear bulkhead and dash. The original Cheetah has a deeply recessed dash for the driver. This was necessary to create enough room for the steering wheel. I have very good room.
- One of the original Cheetahs had the roof cut off which created a roadster. Shell Valley followed the original design of the rear deck. It's pretty much a low flat piece that blends up into the rear wheel arches. It looks fine to me. But I didn't like that it makes it appear that the driver is sitting very high in the car. I made my deck higher and blended in a gentle arch into the rear wheel arches.
- I angled my rear deck down towards the rear.
- I tried to make my car as low and sleek as practically possible.
I wasn't trying to build a replica. Just a cool car that borrowed the parts of the Cheetah styling that I liked. I'm having fun.
I purchased the body shell from Mr bruce and have heavily modified it from there. It was a great starting point. The parts were very nice.
