Old 12-16-2017, 06:59 AM
deano59 deano59 is offline
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
will replace the ugly fuel rails as well. i had to retain as much of the ve shifter as i could as theres not much out there aftermarket for the 6 speed auto shifter wise . i bought a lokar 8 inch bent shifter and turned it around and then put on there lock out gear knob so i can lock it park took so work underneath the trans tunnel to connect the linkage as there is bugga all room to work with the guys from pace did some mods to my trans tunnel without that there would be no way to fit the trans in there is only a feww mm either side and from the top of the trans to the top of the tunnel . it's been a lot of work and would have been so much easier just to wack in a turbo 400 or even a 700 but i wanted the extra 2 gears i hope it's worth it lol cheers dean
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
