Old 12-16-2017, 07:38 PM
deano59 deano59 is offline
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
Originally Posted by Jaydee View Post
I like the shifter I did the same to mine. I made the lock out with having to push down the gear knob to shift through the gates. I was required to have a pointer and indicator as well as a light.
JD
hi Jaydee
only time i need to depress the button is to put it in and get it out of park the rest of the time it glides thru..pointer and light im hoping to get around that as i have a digital display that tells you what gear your in it runs off the ob port i am hoping that will be enough to keep them happy . its what they use when they do ls and 6 speed auto conversions into 4wd's and they pass with it fingers crossed worse case i can make a pointer easy enough .
cheers dean
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
