12-22-2017, 03:17 PM
GA
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Thanks Tom for your update. I have an update too.
The 6642 were too big in diameter and width and would not fit. I had to return them.
On the front I have the 6654 these are a perfect fit.
The back tires are 6641 and sizing to fit the car without interference. And although it is not recommended that these be installed on a rim that is wider than 10" I mounted them on my 12" rims and they look good and fit well. I adopted the position that these are temporary and will do till I replace them with larger diameter 17" or 18" rims and tires in the future.
The ride is much smother and handling much improved with the MT tires as compared to the BFG tires.
