Old 12-26-2017, 04:26 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by 2bars View Post
I own a SPF, I picked it over the CSX for a couple of reasons. The first and main, was how I fit in the car. Hillbank has both in stock so you should test fit. The second reason, more of a bonus was the top, heater, defroster etc that came with the car.
I chose a CSX for that precise reason! I sat in both and the steering wheel on the SPF hit me in the lap.
Bottom line and the advice I give everyone is that you SHALL NOT buy any Cobra until you sit in THAT CAR! This is especially true if you are looking at models that are more than a few years older than one that you test fit. SPF made several changes as the generations progressed so fitting in a newer one won't necessarily mean you'll fit in an older one. Same for early CSX vs later ones. Just try it on.
Note that CSX come with defroster/heater too. (At least mine did) It's required! Don't get one without it. First time I was in a little bit of rain the windshield fogged up. (The wind kept the rain out, until I happened to hit a stop light!)
Tony
CSX4005LA
