  #30 (permalink)
Old 01-05-2018, 12:32 AM
rsk289's Avatar
rsk289 rsk289 is offline
Cobra Make, Engine: 289 leafspring, r/p
Alf,
The shifter bracketry sits in the same place on a T10 as it does on a toploader.
What you have in the photo is very common to a lot of cars. Many of the cars I have seen, including originals, are so tightly packed at that point that modifications have been made to allow a little more clearance. Replica manufacturers tend to make the floorpan in that area work as a set of neat straight lines, which will allow the much more common T5 or Tremec or whatever to fit OK, but not the toploader/T10. The originals I have examined here have either more room or have modified floorpans to help with clearance. I actually cut and reshaped the shifter levers on my car when I had the toploader in there, which worked perfectly - and when I switched to the aluminium T10 I modified the floorpan and did some minor panel beating on the trans tunnel to accommodate it. I think your drivetrain is mounted correctly.
This problem isn't new to replicas or originals - these are all handmade cars with plenty of variation.
