Old 01-05-2018, 04:34 AM
jeclarke jeclarke is offline
Default SP03174 Brake Master Cyl
While inspecting my new roller and getting it ready for the engine installation I found the brake master cyl leaking. The reservoir is almost empty. Fluid seems to be leaking at both of the rubber seals between the reservoir and master cyl it is mounted on. I’m thinking I need a new master cyl. All of this is tucked under the left front fender. Does anyone know if the master cyl can be removed from the booster with the booster in place? There isn’t much room to slide the master cyl forward.
Thanks,
John
