Originally Posted by Dwight
this is not a SPF but an Unique.
I think the tubes that are used as a spacer between the body and jacks are to long.
I don't know that there is a standard length. I have just cut the tube so the jack is closer to the body. Eyeball it
Maybe some of the SPF guys can measure their and post the length.
Dwight
I am going from bumpers to these and I know the rear is out too far and of course the fronts are currently staggered. The bolt in the sleeve is adjustable from what I can see, just a matter of cutting the sleeves if needed. Based on pics I would say the fronts would be the same distance as the lower bolt on the bumper install, which is about 3.25" from the back to the grommet. Top is also 3.25 right now but with QJ's would be less. So the question is, what is your bottom front bolt measurement and rear?
Incidentally the bumpers are for sale, will post in the FS section once off. I would rate them 9 out of 10.
