Old 01-14-2018, 04:09 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
What's wrong with 22 psi hot at idle?
Does the oil pressure go up with rpm? If so, I wouldn't try to fix a problem that doesn't exist.
Exactly.
Dropping from from 30 psi cold to 22 psi hot is perfect.
Many other engines have larger pressure changes.
What pressure does the engine have at 3000 rpm hot?
