Old 01-18-2018, 02:02 PM
cycleguy55's Avatar
Originally Posted by hotrodyankee View Post
Last summer, when I bought my B & B Cobra, the previous owner had rear disc brakes installed, using the GM Metric Single-Piston Calipers.
As of now, I have no emergency brake, due to using the calipers that are on it now. I would like to know if anybody knows the years and application for the Rear Metric calipers with the parking brake provisions, so I can hook up my cables and have an emergency brake.
All info appreciated. I know someone knows the application and/or parts numbers for the calipers that I need.
Thanks, Mike
Based upon what you wrote it's not clear to me whether your calipers have provision for emergency brakes and they're not working, or your calipers don't have e-brake provisions. Please advise.
I have a set of GM rear single piston calipers on my Ford 9" axle - installed them myself from a kit I bought (MGP, I believe EDIT: MBM). They're the 'large' calipers that preceded the 'metric' calipers, but I believe the designs are very similar. I do remember the rear caliper adjustments were a critical part of the installation, plus there are strong warnings that you need to use the e-brake on a regular basis or you will lose the function of the rear brakes. Sample instructions on page 7 of this: http://www.jegs.com/installationinst...600_630601.pdf
Brian
