  #29 (permalink)
Old 01-19-2018, 11:38 AM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
I have the QuickTime Bellhousing and a Tremec 3550 with the 26 Spline input shaft which then calls it a TKO. I had ran the normal Tremec shifter and after a period of time it got stuck in 2nd gear. The cause was due to the shifter allowing me to push the transmission forks further than they should go resulting in the fork shift pads (nylon) breaking and causing jamming in gear. I changed the fork pads to the bronze ones and went with the Steeda which has adjustable stops which prevents pushing the forks further than they are supposed to go. I really like the Steeda and the Olthoff suggested open palm shift allows for it to hit 3rd gear without any hitches.
Phil
