Old 01-19-2018, 01:28 PM
Cobra #3170 Cobra #3170 is offline
Default Cones
Originally Posted by Alfa02 View Post
Scott, this series count's if the cone has moved? (But is still in it's Box?) As you know SCCA doesn't as long as it's still in the marked box. I've ran over a few bases, over the years (Moved the cone) but was still in marked area, as I'm sure you have. I can see the side pipes exhaust moving a cone. A course worker should have seen that. Good luck at Crows Landing. Tom.
This is not Scott it is Bruce, GoodGuys charged 2 seconds if a cone wiggled even if it was touching the box. The course worker called it, for 2018 it will be 1 second if in box and 2 seconds if out. We are looking at rotating the exhaust up so that it won't blow pylons down. The car had a touch of understeer because of the new low friction rear suspension. We are increasing the rear spring rate so that it will hold a tighter line on Goodguys courses..
