Old 05-28-2002, 04:40 PM
Hi Group. Super Ford did a test in the June 1989 issue on what you want to know. I Properly tuned set of Webers will make more tork and Hp. than a carb of the same flow rating. The mid range is stronger. In the upper rpms, the single 4 barrel will win out. They make webers up to 58mm I Know of 1 motor in a cobra making over 700hp. with dyno sheets at the rear wheels. It takes a lot of time to set up the webers, choke housings, air bleeds, needles and jets. On a 452 Fe with a limit of 7000 rpms no single,dual, or 3-2 carb set up will beat the webers in mid-range tork and hp. Good luck on your setup for your car Rick Lake
