Old 01-29-2018, 02:19 PM
Locohead1 Locohead1 is offline
Cobra Make, Engine: A&C, 347" Stroker
Originally Posted by saltshaker View Post
I switched mine to QA1's big change... using ds402 & ds502 shocks, you will also need 4 stud kits. Well worth the money
Jon
Thanks saltshaker. I did find the QA1 shocks you mentioned. It looks like the DS402 goes in the front and the DS502 are for the rears.
My current shocks are from Art Morrison and the tops on all four shocks are threaded on the piston shaft while the QA1 units are side bolt mounted. Do I have to use a conversion kit to make the QA1 units fit the brackets on the car?
You mentioned a stud kit. What does it do? Can you give me any part numbers so I can look them up?
Do the QA1 coilovers you mentioned come with springs or did you have to order them separately or reuse the current ones you had?
Any additional information would be appreciated. Thanks.
