Old 01-30-2018, 12:46 PM
H-Rod H-Rod is offline
Cobra Make, Engine: Antique & Collectibles, Forte 427 SB, TKO 600
If these are the lights that come with the A&C kit:
For the rear, use a small PLASTIC scraper.
Slide it up under the rubber lip on the taillight lens. Move the scraper around the circle and the lens will "pop" out of the rubber.
You`ll see 3 screws going into the body. There should be 3 speed nuts on the screw threads. Unscrew them. (Don`t forget to unplug the wiring going into the back of the taillight housing)
As for the headlights, there should be a small phillips screw on the underside of the chrome trim ring. Remove that and "pop" the trim ring off.
You`ll see some screws going into the body (once again with speed nuts on the backside) Remove these and the light will come out of the bucket.
(once again, don't forget to unplug the headlight connection)
Clear as mud?
LOL!
