  #30 (permalink)
Old 02-01-2018, 04:22 PM
hotrodyankee hotrodyankee is offline
Cobra Make, Engine: 2001 B&B cobra
Thanks for the info. The calipers are new. When I started to assemble everything on the car, I had to back off the lever[small amount] to get the pads over the rotor then re-adjusted the e-brake. As it is assembled now, there is a 1/4" gap between the lever and the lever stop when the e-brake is applied. Drove the car for a bit today[35 degrees out] didn't seen to stop that well. The calipers I replaced were the wilwood single piston style that look like a GM metric, and those stopped good, but with no park brake provision. Thanks again!
