Thread: Tuning question
Old 02-02-2018, 06:53 PM
TexasSnake TexasSnake is offline
Cobra Make, Engine: B&B Ford FE from Southern Automotive
I'm running a similar setup and can tell you that the engine should idle just fine with 10 inches of vacuum. I would check the rocker arm adjustment to make sure you are within range that the manufacturer has recommended. I can also state that on my motor you can definitely hear that it is a solid lifter camshaft. I also set my idle around 950 rpms as low rpm idle setting can be very hard on solid lifer camshafts. There is a lot of load on the camshaft lobe as the lifter begins to ramp up the cam lobe.
