Thread: Tuning question
Old 02-02-2018, 10:55 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
A cam of that profile should quite happily idle under 1000.
Can you not get to run slower than 1000, or does it stall at slower than this?
Should run at 850 at 16 degrees.
I would check the valve lash is set to the recommended lash.
The carb is probably on the lean side and needs some idle feed restriction tuning.
Gary
