Old 02-03-2018, 04:06 PM
steve meltzer steve meltzer is offline
Club Cobra Member
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
Just in from the garage and took off the intake from the cast iron 427 SO, only to discover two seemingly new issues....one is new for sure.
1) Not sure this is new, but as I removed the push rods, i noted that two of them, at least, were bent. I was so flabergasted that I didn't pay attention to whether or not they came from the same cylinder. That sure seems weird to me, esp. since the car never gets driven hard. Other than replacing them, anything i need to watch for, or check first??
2) There was clearly a broken tooth on the distributor drive gear. About 1/2 broken off. Picture attached. What, if anything do i do about the missing chipped tooth. Maybe Patrick's daughter, a dentist would have a rec! I understand that I'll need to replace the gear, but can i just drain the oil and hope for the best or?? It's mate on the cam.
thanx steve
steve meltzer
"I may be wrong, but I'm never in doubt"
