Old 05-28-2002, 11:47 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
I think that the puller type slave cylinders are more prone to leaking because the rod is attached to the piston directly, without a pivot at the piston / rod interface. Pusher slaves allow the pushrod to pivot at the contact point at the piston, so the piston does not get sideloaded so heavily I never installed puller slaves by choice, they're more expensive and seem to not be as long lasting. A homemade bracket cut out of 1/4" thick mild steel 90 degree angle iron can be bolted to the tranny / bellhousing bolts on the driver's side and attach any pusher slave you like. Make the pushrod out of a 7/16" bolt that you cut to length and round both ends on. Go to NAPA and have the parts guy get out the book, pick a slave with the proper diam. and length for your master cyl and fork throw-distance requirements. This is the setup I preferred, tried a few different slaves over the years, depending on master cyl being used at the time.
