Thread: Tuning question
Old 02-11-2018, 02:45 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by vector1 View Post
What is your dist. advance at idle without the vacuum?
Originally Posted by wolf k View Post
Thanks for the replies, will be checking valve lash first thing.
Gaz64, at 1000 rpm it will remain idling, I can lower it to 950 and it will run there for a minute or so but then eventually die. The carb is a pedestrian 750, good idea about the idle feed restriction.
vector1, unknown what the base timing is, I do know total advance without vacuum is around 32-34BTDC
Are you guys saying 10" vacuum at idle with this cam is normal?
Ok, you set the maximum at 32-34 with a timing light, but we don't know the next critical parameter as in timing at idle??
I see no mention of how much at idle you have.
I would hope it has at least 15.
Gary
