Old 02-12-2018, 01:18 PM
mofo mofo is offline
Default Replaced CR mufflers
Originally Posted by wanab65 View Post
You mentioned you had the stock side pipes. I had the stock side pipes on my 1991 CR and found the motor hanging back at higher RPM (351w). After reading several comments, by those who had already experienced this same problem, I found the 4 inch side pipe actually had only about a 1 inch pass through that was off set from the center line. I replaced the muffler with a more open center line pass through and the difference was very noticeable. Also consider ceramic coating the headers and collectors. I did and the headers and collectors run 110 degrees cooler than the muffler. There is a ceramic coating that comes out looking just like chrome.
What did you replace with? A custom muffler or did you purchase a known aftermarket one available?
thanks
