  #21 (permalink)
Old 02-13-2018, 05:30 AM
Andheeezonit's Avatar
Andheeezonit Andheeezonit is offline
Cobra Make, Engine: Superformance. 427 Windsor.
I believe you changed to a Shaw Stat correct. If you are running a stat extension and did not take note of your clearance, you may have a flow issue, which I believe I cautioned about. More likely to cause a hot motor than the oil cooler stat. Check this out, you may have to have the ID of your stat extension bored, I know I did.
