Old 02-15-2018, 04:53 AM
gcarm gcarm is offline
Cobra Make, Engine: G-Force with LS1
Default Shortened chassis ok?
This is from the RMS website:
A vehicle is classed as individually constructed if it has:
  • A specially constructed chassis (non-production vehicle) or a manufactured replica chassis
  • A widened or narrowed chassis, either in places or along the whole length of the chassis
  • A production chassis which does not retain at least one of the original structural cross-members in the same place for that chassis
  • A substantial change to the arrangement of the engine and driveline, such as engine moved from front to rear or to a mid-mounted position, or if the vehicle is changed from front wheel to rear wheel drive
  • A monocoque construction, where the subframe structure has undergone significant structural change, such as removal and replacement of subframes with structures of a different design, or modification of the subframe rails
It doesn't specifically mention shortening of the chassis, only widening or narrowing of the chassis.
