Old 02-17-2018, 02:25 PM
1795's Avatar
1795 1795 is offline
Speaking from experience, when you go to remove the old boots. crack the adjusting nut on the tie rod end and then mark the threads with some paint before removing the tiered ends so that you will have an approximation of where to set them after you have removed the old boots and installed then new ones. Saves a lot of time as you reset the front end alignment. Also, a little bit of grease on the inside of the boot where the threaded end has to slide through it will assist in an easier installation of the new boot.
Good luck.
Jim
