Old 02-23-2018, 07:19 PM
spdbrake spdbrake is offline
Sounds like you have an original vintage style. The lower bezel has two holes in it and you can use 90 deg snap ring pliers to remove it.
https://images.homedepot-static.com/...5b-64_1000.jpg
https://www.cjponyparts.com/scott-dr...-1966/p/MSK19/
If its stubborn it probably has Locktite on the threads. Heating it with a heat gun will liquify the Locktite once it hits 650F. A soldering iron will work as well, just place the tip at the mating point of threads and nut and heat three areas around the dia.
