Patrick, did you install the hard line configuration? If so, does that mean you never did the BMW " all in one " reservoir installation. Hard lines are the best solution. There are master cylinders that do not require the hose barb insert on the upper body. They would allow all hard lines in the configuration. My hose to barb attachment is contacting the floor. No clearance.
