Old 02-27-2018, 02:53 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
The less gasket thickness you use, the less likely to warp or break your throttle body.
For your setup, a thin one on the bottom and a thick one on top, if you need it for clearance within the turkey pan,
and ONLY if it has compression limiting spacers at the mounting points. Otherwise, two thin gaskets.
Gary
