Old 02-27-2018, 06:30 AM
patrickt patrickt is offline
Originally Posted by Gaz64 View Post
The less gasket thickness you use, the less likely to warp or break your throttle body.
I use the same standard Holley gasket that comes in the rebuild kit both above and below the Turkey Pan. BUT, I use a "pointer type" inch/lb torque wrench on every bolt when working on a Holley. It is very easy to warp and crack them by giving them just a hair too much tightening.
