Old 02-28-2018, 10:06 PM
pormgb pormgb is offline
Banned
Cobra Make, Engine: Rowan Replicars, 352 4V
Originally Posted by Tom Wells View Post
Interesting thread.
Experience would say there might be a need to reinforce the wishbone at the outer end, also:
I fixed that problem by turning down solid round steel so it connects both pieces at the joint, I then tapered the edges and welded the joint penetrating through to the steel round.
I also drilled two holes either side of joint, these holes exposed the steel round, I then welded up the hole securing the round to the lower control arm tube.
Rowan Replicars 1965 Cobra Replica
352 4V, T5, Jaguar Posi rear end with 3.30 gears.
https://www.facebook.com/pormgb/
