Old 03-11-2018, 04:20 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Sounds you are better off waiting for your next engine.
Current compression ratio, piston material, conrods, headgaskets, might as well say whole engine mechanical combo, including the camshaft, dictates whether you can add boost to the mix.
A 750 DP of some sort, with a progressive nitrous system would get you there cheaper.
