Old 03-11-2018, 05:40 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is online now
Originally Posted by Gaz64 View Post
As long as the OP doesn't get the "boost bug", then a Paxton or Vortech low boost blow through should be ok.
The carburettor also needs to be setup for boost pressure, throttle shafts pressure fed etc.
Good point. Much more than that and the whole carb setup will probably not work and require a switch to fuel injection.
And I'll assert that none of these are a "4 day weekend" project. Mechanical installation is one thing but the tuning and other adjustments to the engine (including fuel flow and maybe even require new fuel pumps) are going to take more time than that, and also require expertise that will probably be best done by a speed shop. Consider that expert installation and tuning will probably cost as much as the unit.
I know a guy in Loveland that does really good work (he rescued the fuel injection on my Cobra) if you're interested PM me. I'll have to dig it up since it's been almost 10 years.
Tony
CSX4005LA
