Old 03-12-2018, 03:04 PM
Grubby's Avatar
Grubby Grubby is offline
Cobra Make, Engine: ERA 838
Buzz,
Stub axle seals are super easy. Just unbolt the 5 bolts or so and pull it out. Keep the shims. No special tools needed.
You will see the O ring once it is out.
Replace and reinstall with the same shim.
Do both sides while you are at it. You will thank me later or maybe curse later if you have to do the other side in the car.
The O rings get hard over time and leak.
I think there are only two part numbers for the O rings. Order both if you aren't sure. They are really cheap.
John
