Old 03-18-2018, 11:27 AM
legenmetals's Avatar
legenmetals legenmetals is offline
Cobra Make, Engine: contemporary(2) one with 427 sohc and one with 427 center oiler
I will be fabricating a rear bracket on my car that will locate from the rear LCA fulcrum shafts and a stainless plate that attaches to the diff side brackets to a vertical bracket at the rear that will attach to a cross member that I welded onto the chassis.
Because of the toe in adjustment on your car, the rear tie bar holes that are pre drilled by CWI in their tie bar may not align with the fulcrum bars on your car. Toe in is set using horse shoe shims behind the diff brackets. What is the rear width measurement of the rear fulcrum bars on your car?
I have a CWI tie bar that I won't be using for this reason.
I think my idea will add greater support to the rear of the LCA.
