Old 03-18-2018, 05:11 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by steve meltzer View Post
OK, Got it all set up and running well. My base timing is 21, the total, 36. Got the Holley set up as Patrick suggested, with the idle set by the secondary adjustment. Because of the geometry of the Holley and its underlying Edlebrock intake i had to use a hex-head machine screw, not an Allen head, but it's easy to adjust with a 5/16 wrench. But, and there's always a "but", right? It still leaks from the intake. Gonna get some adult supervision to install next. arrgghh. s
Have you got some pics of your leak?
Oil leak, or vacuum leak?
What bush do you have in your distributor to get 21 and 36?
Gary
