Old 03-19-2018, 11:17 AM
steve meltzer steve meltzer is offline
Club Cobra Member
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
OK, thanx for the info about the intake leak, which was immediately obvious after hard driving at the right rear "China" corner, but using a UV light + dye revealed oil leaking from the front, esp on the driver's side and from the rear not only in right corner, but across the middle. I'm just disgusted as I was very careful in trying to do this job. Does anyone ever use the cork gaskets they always supply for the ends? I never have, but jeez...
Timing: I have an MSD box (6 AL, I believe), a standard Ford FE distributor with the advance locked out and an MSD programmable timing computer (8981) now superseded by a the model 8680. s
steve meltzer
"I may be wrong, but I'm never in doubt"
