Old 03-24-2018, 10:40 PM
legenmetals's Avatar
legenmetals legenmetals is offline
Cobra Make, Engine: contemporary(2) one with 427 sohc and one with 427 center oiler
Default Jag. IRS
I noticed the same issue last week when mocking up my diff. housing.
I am replacing my series-1 with the XJS unit. I found the side brackets to be different between the two housings. I will have to use the XKE brackets with the XJS diff. housing.
I am not sure if using the mixed parts is causing my misalignment. My remedy is to open the hole in the frame crossmember and locate all the parts using an additional washer over the fulcrum shaft that I will locate and weld to the back side of the crossmember.
