Old 03-26-2018, 04:47 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Treeve View Post
Sure, but 4th will still be 1:1 and then you have two overdrive gears which is a wank factor thing and it doesn’t address the ****ful 2-3 change. If you want custom gearing you may as well buy a really good box and not bother with tremec at all but go down the path of a proper box like quaife, for example. The TKO 600 is rated to a continuous 600lbft torque, which is bloody impressive. All whilst offering you a shifter location which is perfect for a cobra without modifications and a slick gear change.
Yes, TKO or a high end Quaife 5 speed would be far superior to a T56.
I've always hated the shifter feel and the worst 2-3 of any cars I know, including most FWDs.
6 speed sells cars, but do you need .75, and then a .50 6th gear?
Gary
