Thread: Tire sizes
  #24 (permalink)
Old 03-27-2018, 02:20 PM
cycleguy55's Avatar
Originally Posted by t walgamuth View Post
What kind of ps are you running? How is the road feel? Will it return itself when you let go of the wheel?
Mustang II PS rack, Saginaw PS pump - modified with both flow (2 GPM - many available) and pressure reduction (Borgeson 899001 kit). If I did it again I'd probably use an adjustable valve like the Heidts Adjustable Power Steering Valve (PS-101). That way you could dial it up for autocross and dial it back down for regular use.
The pump is mounted with a billet aluminum bracket from CVF Racing, and the PS pump pulley is from CVF as well. The crank pulley is from March Performance (it was on the car when I bought it in 2014).
Road feel is okay, not great. Self-centering is not great either, but I haven't taken it back in to have the caster increased - it's still set low for manual steering and needs to be dialed up for the PS.
BTW, I don't make a habit of letting go of the steering wheel!
Brian
