Old 04-01-2018, 04:58 AM
strictlypersonl strictlypersonl is offline
Originally Posted by Ram427 View Post
I would get the rear geometry sorted first, toe in etc before finalising the hole positions.
I suspect that the holes in the plate are there to define where the brackets go (laterally). Use shims between the brackets and the differential to fill any gaps (as the original Jag configuration did).
* That means that the holes in the plate must be located perfectly. No sloppiness allowed.
