Old 04-02-2018, 08:47 AM
Tom Wells's Avatar
Tom Wells Tom Wells is offline
Buzz,
Maybe I'm visualizing this incorrectly, but I think toe would not be affected by axle and wishbone length.
If the toe is correct to begin with, shortening the axle & wishbone would bring the wheels closer to the differential, but the distance between the front and rear of the tire shoulders should maintain the same distance, i.e., the toe-in.
Think of it this way, if I set the tires on the ground at proper toe-in and then move them toward each other along the axle centerline (without turning them about a vertical axis), toe-in should remain the same.
Am I missing something? (probably...)
Tom
