Old 04-10-2018, 03:50 PM
Dan Case's Avatar
Dan Case Dan Case is offline
Original Shelby Owner
The original thrust washers were GARLOCK BEARINGS, INC. G10DU.
There were also four each seals as AC Cars intended that the bushes to last for years without further service.
Original pivot pins have a step down for the shock absorber mount on the forward facing end. The shafts were precision and chromium plated. For repairs I bought hydraulic cylinder shaft material that is very robust and had the parts cut from them. Special washers and thin AerotightŪ nuts went on both ends.
Dan Case
