Old 04-10-2018, 05:45 PM
MAStuart MAStuart is offline
Thank you Dan! I have the bushings and seal. I need to make the plate with the 3 inch hole in it and the shock mount to finish the rear lower a arms. When I am done with that my next project is to make the pins. By the drawings I got it looks like the part of the pin that is 3/4 is the same overall length as the overall width of the a arm where it connects. I plan on using the same material as you stated.
Could you tell me does the end of the pin that just get the special washer and the nut. Does the washer come into contact with the a arm? Also on the shock end. Does the rubber bushing in the lower end of the shock come in direct contact with the A arm? Or does it get a washer put on first? Also does the rear shocks have steel sleeve inside the rubber bushings.
Thanks Mark
